Character > Morph Data (2)
M3D Statham - Body , M3D Statham - Head
Character > Avatar (1)
Statham
- nose septum curve , nose septum curve , skull over ear width , skull over ear width , teeth lower root width , forehead flatten , forehead flatten , lower central incisor root width l , upper central incisor length l , lower lateral incisor edge contour l , upper central incisor move side l , upper lateral incisor edge contour l , upper lateral incisor turn r , lip seam height , lip seam height , lower lateral incisor move side r , lower canine twist l , teeth lower width , upper central incisor twist r , lower third molar length r , lower lateral incisor receed l , nostril upper width , nostril upper width , upper central incisor width l , skull front height , skull front height , upper lateral incisor tilt r , chin middle depth , chin middle depth , lower lateral incisor edge angle l , lower lateral incisor length l , lower first premolar length r , upper lateral incisor tilt l , upper central incisor edge angle r , chin middle lower depth , chin middle lower depth , nose tip lower width , nose tip lower width , teeth upper depth , teeth upper width , lower central incisor root width r , lower central incisor width r , upper canine tilt l , cheek-jowls , cheek-jowls , nostril upper crease define , nostril upper crease define , chin lower depth , chin lower depth , lower lateral incisor twist r , lower canine edge contour l , lower central incisor move front l , lower lateral incisor root width r , upper canine edge contour r , cheek upper hollow , cheek upper hollow , lower central incisor move side r , lower lateral incisor edge contour r , ear center in out , ear center in out , lower canine width l , lowercentral incisor tilt r , lower central incisor edge contour r , teeth scale width , chin crease height , chin crease height , lower central incisor receed r , mouth under curve , mouth under curve , lower lateral incisor turn r , upper lateral incisor root width r , lower central incisor edge contour l , nose ridge middle width , nose ridge middle width , teeth height , lower canine move front l , lower canine edge contour r , jaw outer angle , jaw outer angle , upper lateral incisor length l , teeth lower height , lip upper flatten , lip upper flatten , lower third molar length l , face square , face square , lower central incisor edge angle r , upper lateral incisor move front l , lower canine move front r , upper lateral incisor move front r , lower central incisor receed l , lower central incisor twist r , upper central incisor width r , lower canine length l , teeth lower scale back width , eye opening , eye opening , lower central incisor edge angle l , skull back neck depth , skull back neck depth , teeth lower front width 1 , upper central incisor twist l , upper central incisor edge angle l , lower lateral incisor turn l , upper central incisor length r , upper central incisor tilt l , upper canine length l , brow contour , brow contour , teeth root width , nose septum angle , nose septum angle , upper lateral incisor twist l , chin middle upper depth , chin middle upper depth , upper central incisor root width l , upper central incisor receed r , teeth lower length , lower canine length r , lower canine width r , lower first premolar length l , lower lateral incisor width l , lower lateral incisor twist l , teeth lower depth , upper lateral incisor edge angle l , nose ridge offset , nose ridge offset , upper canine twist l , head lower width , head lower width , teeth upper length , lip lower outer depth , lip lower outer depth , lower lateral incisor width r , upper central incisor move side r , skull front depth , skull front depth , lower central incisor twist l , lower central incisor move front r , lower canine turn r , chin upper depth , chin upper depth , upper central incisor turn r , upper central incisor root width r , upper lateral incisor twist r , upper canine turn r , upper central incisor edge contour r , upper canine edge contour l , nose greek , nose greek , lower lateral incisor edge angle r , upper lateral incisor move side l , lower lateral incisor receed r , lip upper scale height , lip upper scale height , upper lateral incisor outer chip l , lower lateral incisor length r , ear upper in out , ear upper in out , upper central incisor receed l , upper lateral incisor edge contour r , lower central incisor length l , teeth depth , lower central incisor move side l , upper canine twist r , lower canine receed l , lip seam curve , lip seam curve , lower central incisor width l , lowercentral incisor tilt l , lower central incisor length r , upper central incisor edge contour l , lower lateral incisor move side l , upper canine turn l , lower canine tilt l
- pack-mouth10-Lips Square , pack-mouth10-Lips Square , pack-mouth1-Lip Lower Depth , pack-mouth1-Lip Lower Depth , pack-mouth9-Lips Heart , pack-mouth9-Lips Heart , pack-mouth4-Lip Top Peak , pack-mouth4-Lip Top Peak , pack-mouth14-Corner Of The Mouth , pack-mouth14-Corner Of The Mouth , pack-nose1-Nose Bridge Height , pack-nose1-Nose Bridge Height , pack-nose6-Nose Ridge Width , pack-nose6-Nose Ridge Width , 2015-12-29-10-07-12-Aquiline nose , 2015-12-29-10-07-12-Aquiline nose , pack-jaw13-Chin Recede , pack-jaw13-Chin Recede , pack-nose26-Nose Tip Slope , pack-nose26-Nose Tip Slope , pack-mouth2-Lip Lower Size , pack-mouth2-Lip Lower Size , pack-nose10-Nose Septum Depth , pack-nose10-Nose Septum Depth , pack-mouth11-Mouth Curves , pack-mouth11-Mouth Curves , male african-body , male african-body , pack-nose25-Nose Tip Flat , pack-nose25-Nose Tip Flat , pack-nose8-Nose Tip Depth , pack-nose8-Nose Tip Depth , 2016-01-08-09-55-55-Mouth Sphincter , 2016-01-08-09-55-55-Mouth Sphincter , pack-eye106-Eyelid Smooth , pack-eye106-Eyelid Smooth , pack-nose5-Nose Ridge , pack-nose5-Nose Ridge
M3D Statham
• This pack does not include skin textures(The skin textures used in the demo image is 'CC3+_Caleb').
• The pack does not include hair or outfit.
My other Character Packs:
