I was going to call this one "Magic Missile!" but feared the wrath of Gary Gygax's ghost, so went for "Magical Missile!" instead.  Wise, huh?
Anyway, that's what it is meant to be: a magic projectile for your local Magic User / Wizard / Mage / Sorcerer, etc.
And it's an older one in my collection that I wasn't happy with when I first made it, but now have come back and updated it and fixed it up a bit.  So I think it's good to go!
It comes with three options for shooting a Magical Missile - a short range blast, a mid range and a longer range (Short is about 5 metres, Mid is 10m and Long is 15m, if I understand distances in iClone correctly, which I may not...)
Anyhoo, the Legacy Particle Emitters are attached to the dummy prop.  The dummy also has the AML/LUA script embedded in it.  Simply right click the dummy, select Perform then one of the 3 Blast Options to start the effect/s.)
Check out the pictures for examples, then enjoy all the fun of blasting your worthless opponents to atoms!  hehehe
Note:  I should also point out that the effect fires from the apex of the dummy pyramid (straight up) - so you'll want to rotate that for better aim (I did this for hopefully easier targetting...)
And remember:  If you like it, why not rate it and leave me some feedback!
THANKS!
Universal
