For iClone only:
Actor > Non-Human/Creature (1)
Set > Props (1)
Animation > iMotion (26)
Bigboss is proud to announce the arrival of a series of absolutely outstanding and stunning fully animated Creatures by PROTOFACTOR.
This is the MANTICORA Creature by PROTOFACTOR.
This Pack contains a MANTICORA Creature for iClone plus 26 high-quality Custom Motions. The Creature is supplied both as a Non-Human Avatar and as an iClone Prop with embedded animations.
About PROTOFACTOR Creatures:
Each PROTOFACTOR Creatures uses high quality texture maps and a very small polygon count providing excellent visual quality for close-up shots. The Prop version of the Creature provides additional functionalities such as the capability to use the multi-duplicate iClone feature and the capability to apply key frames to the scaling of bones which may be required by some of the provided custom animations.
Method of use:
1) Simply Apply the Animal Avatar or Prop to your scene
2) Right Click on the Animal to select the appropriate performance
3) You can alternatively Drag&Drop motions on the Avatar version of the Animal
4) Use the iClone "Multi-Duplicate" tool to clone the Prop version of each Creature along a vector or circular path.
5) Edit the applied animations on the timeline to add randomness to each character move.
6) Another interesting trick is to attach all your Creatures to a dummy Prop and have the prop follow an iPath during the animation !
Have fun!
Method of use:
Have fun!
