  • Set > Props (425)
Master Builder works in both iC5 and iC6 & has everything you need to create a complete, functional building in just minutes - & a complete town's worth of functional buildings in under an hour!
There's no aligning components - just click your mouse, everything falls into place, saving you countless precious minutes. Everything is textured with a wide variety of options to suit any theme or motif, from modern structures to ancient, residential, religious and commercial. To add windows or door in any wall, just click to hide the opening in your scene manager. Easy filming because you can make any component (or sub-component) invisible with a mouse click in your scene manager.
Use the extension sets to expand your building to the east or west or both! Naming conventions match so the extension will align with the original item (for example roof 3 has extensions for the east & west that are also option number 3 - so no hunting for the matching extension).
With the main & extension components in this pack, you can literally create thousands of unique buildings (buildings in the promotional images below were made with this pack). You can also utilize the components to create additional variations by detaching sub-props and moving them to your desired location. See the promo images for just a few samples of some of the components in the pack.
Doors & windows with built-in animation for opening/closing.
Also, the weathervanes and the bell in the church roof have built-in animation & SOUND! Please take note that you MUST rename the file extensions of the sound files from ".iProp" to ".mp3" BEFORE you use those particulare roofs. The path for the sound files typically is: C:\Users\Public\Documents\Reallusion\Template\iClone 5 Template\iClone Template\Props\GJ3D\MasterBuilder\Sounds - if you store your iClone content on a drive other than C:, you will need to create this same path and copy the 3 sound files into it.
Master Builder Basic Instructional video
Instructional video - BEYOND THE BASICS
Master Builder Add-On packs - more options for your scenes:
Universal
