For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (43)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animated Custom Characters by Arteria3D.
This is the Female Mercenary by Arteria3D.
This Pack contains the Female Mercenary Character. This fantastic character is perfect for any Fantasy or Medieval scenario. Equipped with a sword, and stealth, she seeks her assignment from the highest bidder and can never be trusted. This character was ported to iClone by Bigboss. She is presented as a non-human .iAvatar that can be fully animated inside iClone.
The Character comes with his own AML persona plus a Motion Pack consisting of 43 high quality motions including a large library of sword moves that can be used for all your Medieval action needs! The Walk, Run and many of the normally repetitive motions are perfect cycles that can be repeated on the timeline. Required transitional motions are also provided and you can operate the Character in iClone Director Mode !
IMPORTANT NOTE: The Motion files for this Character must reside in the "$iClone Template\Motion\FemaleMercenary\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e. create a \FemaleMercenary\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
Standard Human
