For iClone only:
  • Actor > Legacy Standard Human (3)
  • Animation > iMotion (14)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Non-Human Characters by Arteria3D.
This is the Medieval Horse Base by Arteria3D.
This Pack contains 3 Medieval Horse Avatars (One Plain Horse plus 2 Clothed Horses with different Material bases). The Horses were ported to iClone by Bigboss. They are presented as non-human .iAvatars that can be fully animated inside iClone.
Furthermore, the Medieval Horses come with AML persona and 14 high quality motions; Bite, Death, Eating, Galloping, Idle, Jump, Kick, Kick_Ground, Looking_Around, Rear_up, Running_Death, Sniff, Trot and Walk. The motions are perfect cycle that can be repeated on the timeline.
IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\HorseBase\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 5 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \HorseBase\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu.
Note: This Pack requires iClone 5.3
Have fun!
Bigboss40@videotron.ca
Standard Human
