For iClone only:
  • Actor > Legacy Standard Human (2)
  • Character > Cloth (5)
  • Character > Shoes (1)
  • Set > Props (1)
Base Content
Medieval Males
Created using the Winter Coat base from Street Fashion & the Cloak & Cloth Belt from Playset Assassins. You must own these packs or the bases linked to use these characters. If you don't want to buy the cloak, remove it and the watermark will go away.
Works well on female character as well - see promo.
Supplied as two characters that will install in iClone 7 - Avatar/CC_Alley/Medieval_Males
Supplied as "Cloth" in Character Creator - Cloth/Others or Shirts/CC_Alley/Medieval_Males
As with all my cloth textures, you get customized RGB maps and you can launch in the "Appearance Editor" to make your own texture variations. Custom Normal & AO also added to the Mesh Data (otherwise jackete would have the quilting embedded and if you removed this, there would be no wrinkles). Just pointing out the added value in my packs that are not present in many others.
The tights were created using a decal. If you want to change skin textures in CC, the tights will disappear. Changing body parameters will not affect it. There is an iClone "plane" prop supplied in this pack with the png file attached to use in Character Creator. Open the Prop in iClone and save the diffuse as a PNG. In CC, load the appearance editor for "Skin", select "Decal 1" and add the saved PNG to the diffuse channel. Make sure the WH & W scale are both moved to 1.00.
Also, inside CC, the auto "Hide Mesh" feature may leave a hole in the character near the neck. To remove in CC, with Winter Jacket highlighted in the Scene Manager, select "Conform". Then select "Cloth Layer Settings". Then select "Auto Hide Mesh". This should bring the skin back. Alternatively, inside iClone, simply uncheck "Hide Inner Mesh".
Supplied iClone characters will have default hair and scabbard in promos (from Assassin Pack) is not included. Boots are default from iClone 7 (called Punk Strap Boots). They will install in CC in a folder Shoes\CC_Alley\Medieval_Males.
CC1 CharacterCC1 CharacterUniversalCC Component
PBRExtended
