For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (20)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animated Custom Characters by Arteria3D. This is the RedKnight by Arteria3D. This Pack contains the Elystian Red Knight, a fearsome Knight of the Highest Order of Respect. Great for a medieval or fantasy scenario. The Red Knight was ported to iClone by Bigboss. He is presented as a non-human .iAvatar that can be fully animated inside iClone. The Red Knight comes with his own AML persona plus a MEGA Motion Pack consisting of 20 high quality motions that can be used for all your Medieval and Fantasy action needs! The Walk, Run and many of the normally repetitive motions are perfect cycles that can be repeated on the timeline. Required transitional motions are also provided and you can operate the Character in iClone Director Mode ! IMPORTANT NOTE: The Motion files for this Character must reside in the "$iClone Template\Motion\Redknight\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\ Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e. create a \Redknight\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu Have fun! Bigboss40@videotron.ca
Standard Human
