Actor > Legacy Standard Human (1)
Animation > iMotion (13)
This is the Roman Guard by Arteria3D.
This Pack contains the Roman Guard, great for any historical or fantasy scenario. The Roman Guard was ported to iClone by Bigboss. He is presented as a non-human .iAvatar that can be fully animated inside iClone.
The Roman Guard comes with his own AML persona plus a Motion Pack consisting of 13 high quality motions that can be used for all your Medieval and Historical action needs! The Walk, Run and many of the normally repetitive motions are perfect cycles that can be repeated on the timeline. Required transitional motions are also provided and you can operate the Character in iClone Director Mode !
IMPORTANT NOTE: The Motion files for this Character must reside in the "$iClone Template\Motion\RomanGuard\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e. create a \RomanGuard\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
iClone > Actor > Humanoid > Historical Humanoid
iClone > Motion > Combat > Armed Attack
