Set > Props (2)
This an iClone 7 Medieval Stocks set. Comes with the Stocks and a padlock to lock them.
Both the stocks and padlock are animatable iProps. While they do not come with any perform actions, the components have been made using iClone sub-props which have been pre-position and their pivots set to make animating the props very easy using the regular iClone translate and rotate functions.
To animate the opening and closing of the stocks, click on the top sub-prop of the stocks dummy object and rotate. Since the pivot has been aligned with the hinge, a simple rotation is all that is needed.
To animate the opening and closing of the padlock, click on the padlock loop sub-prop of the padlock prop, translate the loop (ring) away from the base and then rotate.
By default, the stocks come with anti-chafing inserts for the neck and wrist holes which is typically suitable when using the stocks for some consensual bondage roleplaying. When using the stocks for an actual historial film or similar the inserts can be removed by simply deleting the inserts sub-prop under the stocks dummy prop.
Contains:
1x iC7 Stocks iProp (containing a Top, Bottom and Inserts sub-prop)
1x iC7 Padlock iProp (contianing a padlock and padlock loop sub-prop)
iClone > Set > Props > Historical Prop
