For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (66)
This is the Medieval Thief by Arteria3D.
This Character comes with AML plus 66 storytelling medieval motions including sword moves and everyday motions, allowing for a total freedom and expression when adding characters to complement your medieval scene. This character is a great additions for any medieval or fantasy scenario. The character is presented as a non-human .iAvatars that can be fully animated inside iClone. The motions are carefully crafted to provide expressiveness through a wide range of sword moves and story telling possibilities. This characters can also be operated in iClone Director mode.
MOTIONS INCLUDED WITH THIS CHARACTER
Walk, Sword_Walk, BackWalk, Run, Jump_Running, DiggingA, DiggingB, Disappointed, Drinking, Eating, Explanation, Getup, Goto_Sleep_Pose, Moving_Left, Moving_Right, NPC_Idle, PointingA, Sit_Down, Sleeping, Stand_From_Sitting, Standing_Free, Stretching, Swimming, Tracking, Use_Object, WakingUp,
CombatIdle, Dodge_Backwards, Dodge_Left, Dodge_Right, Duck_Below_High_Swing, DyingA, DyingB,
Hit_From_Back, Hit_From_Front, Hit_From_Left, Hit_From_Right, Shield_Block_High_Front, Shield_Block_High_Left, Shield_Block_High_Right, Shield_Block_Low_Front, Shield_Block_Low_Left, Shield_Block_Low_Right, Shield_Block_Mid_Front, Shield_Block_Mid_Left, Shield_Block_Mid_Right,
Sword_Parry_From_Straight_Down, Sword_Parry_High_Left, Sword_Parry_High_Right, Sword_Parry_Low_Front, Sword_Parry_Low_Left, Sword_Parry_Low_Right, Sword_Parry_Mid_Front, Sword_Parry_Mid_Left, Sword_Parry_Mid_Right, Sword_Swing_High_Straight_Down, Sword_Swing_High_Left, Sword_Swing_Hight_Right, Sword_Swing_Low_Left, Sword_Swing_Low_Right, Sword_Swing_Mid_Left, Sword_Swing_Mid_Right, Sword_Swing_Parry_High_Right, Sword_Trust_High, Sword_Trust_Mid, Sword_Trust_Low
The Walk, Runs and many of the normally repetitive motions are perfect cycles that can be repeated on the timeline. Required transitional motions are also provided and you can operate the Character in iClone Director Mode !
IMPORTANT NOTE: The Motion files for this Character must reside in the "$iClone Template\Motion\MedievalCharacters\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e. create a \MedievalCharacters\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
Standard Human
