Lookingt for a mermaid for your scene? Here's a PBR Mermaid actor with Spring effect Hair, pectorals, and mertail. Pelvic fins have weight mapping for dynamic movement as well. The hair on this mermaid can be swapped over for other hair you may have in your library. Try out different colors in the diffuse tab for a variety of mermaids. *Note Spring Objects effects may vary depending on actors movement. They can be disabled and adjusted within your modify tab in Iclone.
Facial & Body Ready Character
PBR
