MIDI_Piano_Player (MPP) is a FREE iClone Plug-in that can import a MIDI file and use that file to animate
the keys on a G-Tools keyboard prop*, allowing you to 'sync' music and animation. Sample MIDI and audio
files are included with the plug-in to help you get familiar with its use.  There are separate versions
of the plug-in for iC7 and iC8.  Please see the READ_ME.TXT file included with the plug-in for full
instructions.
*NOTE: MPP was designed to work only with "GT-Keyboard" props, available in the RL Marketplace here:
https://marketplace.reallusion.com/gt-keyboards
Although MPP will animate using just a MIDI file, for best effect you will want to have both the MIDI file and the
audio file that matches the MIDI file so your animations will 'sync' to the music.  Only one GT-Keyboard
can be animated in the same iClone Project, since the different keyboards share the same prop (Note)
names.  MPP requires minimum 1920 x 1080 resolution.
Readme file: MPP_README.txt
UniversalIC-Non-Exportable
