For Character Creator only:
  • Character > Head Morph & Skin (1)
  • Character > Morph Data (1)
  • Character > Project (1)
  • Character > Skin (1)
For iClone only:
  • Actor > CC Standard Human (1)
4K PBR Digital Human Skin
Designed for the Digital Human Skin Shader and Real-time Rendering
Head Morph Slider - For the slider to appear in the Morphs list you must go to ->> Help>Refresh Sliders.
Preset with skin
Project file
iAvatar file
-Please note, when using the head preset with skin you may want to re-apply the skin to remove any seams.
Before using the preset make sure your base has the digital human shader applied.
When applying the morph slider make sure you start with the neutral character base or you will get different results.
All example photos and videos are rendered in iclone 7
Be aware that rending in I-Ray may give you different results.
All clothing you see in photos are included in the project file. - In order for the hair to work you need to purchase it seperatly by going HERE - once you remove the hair the watermark in the project file will be removed.
If you run across any issues please contact me for assistance.
CC3 CharacterCC3 CharacterCC3 CharacterCC3 CharacterUniversalCC Component
Extended
