# MotionTrigger above 2.1 is for iClone 8.02 or above.
# MotionTrigger below 2.01 is for iClone 7.8 ~ 7.93.
Future maintenance will only be on the IC8 version.
Motion Trigger for IC7 will no longer be maintained unless serious problems are reported.
Motion Trigger can use Hot Key or Mouse Click to trigger motion quickly.
Some iClone embed motion has been put in Motion Trigger, you can use Motion Trigger Tool to customize your own motion.
How to Install:
  1. Unzip the downloaded file.
  2. Copy Motion Trigger folder into the iClone install directory > ...\Bin64\OpenPlugin.
Try Before you Purchase.
  • Please click "Free trial download" in the upper right corner of the page.
Main Note:
  1. If plugin not show, Please update your Windows operating system to the latest version.
  2. There is a limitation to using "Get Motion Data" to customize motion:
    • If the motion distinguishes whether there is an Export License or not, only the version of Export License is supported.
    • Not support the motion which is Trial version.
    • All support if there is no distinction.
  3. About iClone 8
    • The Facial Motion Trigger is only support the Facial Profile of character with Traditional System.
    • The motion data cannot be loaded into versions below v2.1.
About Trial Version:
  • The trial version does not provide "Record", "Add Group", "Build Group Profile Tool" and "Load Group Profile" functions.
  • The number of motions that can be used will be limited.
About upgrading:
  • If you are a user who has already downloaded old version, please back up the old plugin. Old and new version cannot coexist.
Resources:
More information is in "README.txt", iClone 7 and iClone 8 have different restrictions, please read it in detail.
Readme file: README_V2_10.txt
UniversalIC-Non-Exportable
