For Character Creator only:
  • Character > Morph Data (2)
  • Character > Project (1)
Mr and Mrs Clay by PIXTIM
CC Sliders for Character Creator 2.
Can be used with Iclone 6.5 or Iclone 7
(With Character Creator 2, export your character to the version of your choice)
With these characters sliders, you will be able to use most of the clothes of your Character Creator 2 library. The polygonal mesh has been organized to get the least distortion on the texture distribution. Thus, pants or a check shirt will work as well as on a normal human figure.
IMPORTANT:
_ When using the Mr and Mrs Clay characters under Iclone, consider disabling the auto blink function of the eyes.
_ Sometimes pre-recorded animations incorporate movements of the neck or facial structure that can cause unwanted deformations on the smooth faces of Mr and Mrs Clay.
Content :
_ 1 white character CC presset (Content window -> Actor Project -> Base -> Pixtim)
_ 2 Morph Sliders (Morph Window -> Pixtim -> Mr Clay and Mrs Clay )
Method of use:
_ On Character Creator 2, for Mrs or Mr Clay, start with the character presset "PIXTIM_White_Base" and after use the slider Mr Clay or Mrs Clay to 100%.
In Character Creator 2, you can use most of the sliders that allow the body to be adjusted except the "full body" sliders that also affect the face.
If you want to reduce the chest size of the female character, you can use the cursor "Chest" with a negative value.
The clothes used in promotional images are not included with the Mr and Mrs Clay models. These clothes come from the Essential Clothing and Professional Outfit packs.
CC1 CharacterUniversalCC Component
Extended
