For Character Creator only:
Character > Project (1)
Character > Cloth (4)
Multi Empire Gown Pleated This pack is the first of several styles of Empire style gowns that are in progress. Each pack will contain a top and a bottom mesh that will be able to be mix and matched. The next pack will be a non pleated style for both the top and the skirt. This means the pleated sleeve top can me added to the non pleated skirt. This pack comes with UV maps and the 2 parts of the gown which you will find in cloth/Full-Body/Delerna/Multi-EmpireGown The UV map for the skirt piece has some tips written on it for opacity and physics weight mapping for this skirt It also has the base female character I used in my video that you will find in Project/Base/Delerna and it is called EmpireGownTester Be aware that based on the type of animation applied to a character, the shapes of the characters body and the opacities placed on the outfit may require modifications to the collision shapes, body opacities or physics weight mapping to suit. Note: The physics weight map has a black edge at the bottom which prevents the skirt from twisting through the legs in vigorous animations such as Heidies graceful dance when she spins a lot. However, in most animations such as walking, running, where the character doesnt spin a lot then you can edit the weight map and make the bottom edge white. That will make the cloth flow at the bottom much better. If you make that edge white and do Hidies cat walk animation you will see the cloth flows fine. Now try it with Heidies gracefull dance then you will see what I mean. Put the black edge back on the bottom and now it flows fairly well on the gracefull dance.
