  • Character > Cloth (9)
There are 9 gowns in this pack 3 no belt ......with 1 floppy sleeve, 1 floppy forearm, 1 tight sleeve 3 thick belt .. with 1 floppy sleeve, 1 floppy forearm, 1 tight sleeve 3 thin belt ... with 1 floppy sleeve, 1 floppy forearm, 1 tight sleeve The 3 no belt gowns and 2 of the thick belt gowns have different opacity maps. I suggest you save them so any of them can be added to any of the gowns The 5 opacity maps I called v neck, square neck, round neck, heart neck and halter neck and they are 1024 by 1024 pixels. Also the 2 thin belt gowns that have floppy sleeves have a UV map in the specular map, and I suggest you save these also. They are 4096 by 4096 pixels so the UV lines are as thin as possible. Use these to create your own opacity maps, RGB masks, diffuse textures etc etc. There are 2 because there is a slight difference in the UV map for the gowns that have belt straps and the gowns that don't. For the Belt Strap gowns the UV map has a slight gap between the belt and the rest of the gown. This is so the belts edges can be made straight easily. For the non belt gowns there is no gap
CC1 CharacterCC Component
Extended
