  • Character > Cloth (4)
This pack has 3 variations of a smock 1 with tight sleeves 1 with floppy forearm and tight upper arm sleeves 1 with floppy sleeves When downloaded there will be 4. The tight sleeves is added twice with different opacity maps on each. The opacity map for the body is in the Glow map of the smock and each one is slightly different in order to match the smocks opacity map. These body opacity maps help to hide cloth penetrations on the body and are only included as a guide. You may need to adjust them for the characters you use The 4096*4096 UV map is in the Specular Map of the Floppy Forearms version. You should save these as images (especially the UV Map) for guiding your texturing.
CC1 CharacterCC Component
Extended
