For Character Creator only:
Character > Project (1)
Character > Cloth (3)
Please read carefully.
This pack is an extension for Multi Victorian Gown Simple.
If you dont have that pack then you won't have a top
Multi Victorian Gown - Bustle
The 3 parts in this pack can be combined with the top from the pack mentioned above.
Also there will be other extensions comming which can be mix and matched with both of these packs
In the images below are example of using the textures Alley made for the Simple version of the Multi Victorian Gowns on this additional version called BUSTLE.
You will find th contents in Clothes/Full Body/Delerna/MultiVictorianGown/Bustle
There is also a base female character with collision shapes setup that I used in my promo video.
You will find it in Projects/Base/Delerna and it is called Bustle Tester
