For Character Creator only:
Character > Project (1)
Character > Cloth (6)
Multi Victorian Gown Simple This pack contains an outfit split into 3 pieces. Each piece also has a 2048 pixel UV map for texturing. The pack also includes a base female character with the collision shapes I used for the demo video. Dress, Top and Waist ruffle. The waist ruffle can be added as part of the outfit or left off. There will be other styles of dresses and tops comming in the future that you will be able to mix and match. Note I also have another gown called Multi Empire gown that is also split into 2 parts so I can create variations for mix and matching future additions for those too. However, you wont be able to mix and match these ones with the Empire gown because the join edge for this one is at the waist where as the join edge for the Empire gown is just under the breast so trying to mix and match them will have a gap between the top and bottom You will find the outfit and UV maps in Cloth/Full-Body/Delerna/MultiVictorianGows/Simple. The character will be in Projects\Base\Delerna and it is called VictorianGownDemo
