For iClone only:
  • Project > Project (1)
Terrain Project for the Oil Jack Compound by Dexsfot Games
The Dexsoft pack was ported to iClone from Unity as a scene, but the terrain does not come with it. Therefore I created a terrain project that works with the Full Scene Prop included in the Oil Jack Pack. To set things up properly, you should do the following if you have both packs.
1) Load the Terrain Project
2) Add the full Scene to the stage by double clicking. Everything should align together properly.
3) Add the animated Oil Jacks to you scene and activate the Perform menu.
The project includes default trees, and rocks which you can remove or replicate if desired. You can also add more rocks from either iClone default or from the Dexsoft single props in the pack. It also has an IBL environment which you can use or substitute your own.
The terrain's ups and downs were designed around the full scene props level.
Dexsoft Oil Jack Compound can be Purchased HERE
Universal Project
