Set > Props (79)
This pack has been saved as several merged props that will add to the stage in perfect formation to create one full "Diner-Style" restaurant. Counters have subprops with food/cups, etc. Each table has been saved as a prop with chairs/napkins and condiments as subprops. And of course sub-props can be saved as single props for multiple uses.
Additionally the Front Wall, with windows and blinds and front door attached is a separate prop. Door on pivot can be opened and closed. Side and back wall are separate prop. Roof is also separate with drop lights attached as subprops.
I've also added all the individual props which you will find in a sub-folder called "Single Props" so you can add them to this or other projects.
IMPORTANT NOTES ABOUT THIS PACK!!
There was a major problem with this pack as pointed out by a buyer and hence the poor rating. I apologize for this, it was my error (Alley) and I've fixed it now.
The pack installed to Template/Props/SbbUtutuya/Old_Diner and had a sub-folder called Single_Props which was fine. The main folder called Old_Diner contained props that were supposed to add to the stage in perfect formation to form the furnished diner. This did not work.
Please download the pack again, which will now contain a new sub-folder called REV_GROUP_PROPS and these will replace the ones in the main Old_Diner folder which can be deleted once you download again. The new folder props will now in fact load to the stage properly and lined up to create the furnished prop. In addition, the pivots for everything have been corrected so you can move and resize each item. If you have any issues, please contact alley@iclonealley.com and I'll help you. I'm not completely how this will install for previous buyers, so if anyone can let me know how it goes, I'd appreciate it. If necessary, I can create a whole new pack.
NEW BUYERS - DISREGARD THE ABOVE NOTE - IT WILL INSTALL CORRECTLY FOR YOU.
Other packs by SbbUtutuya you might like:
