For iClone only:
Actor > Accessories (1)
Material > Accessories (4)
Set > Props (1)
Bigboss is extremely proud to announce the arrival of a series of amazing special Props and Accessories by Cricky.
This is the One Ring to Rule Them All by Cricky.
This Pack contains a Ring Prop and Accessory with easy to use UV Maps plus 4 starter Materials.
A must have for Lord of the Ring Movies !!!
Method of use:
1) Select Human Character
2) Apply Ring Accessory
3) Customize to your liking using the supplied Materials as templates
4) Apply Prop version to your scene and Animate
This Prop was created by Cricky.
ADDITIONAL INFORMATION
- Prop and Accessory fitting Chuck - Adjust for other characters.
- All Models Shown in the demo video use exactly the same EASY to edit UV Map layout as a guide.
- Any single tiled material that is truly able to be tiled will work to replace or overwrite the entire UV. One such tile was used that was originally setup for floor tile.
- The UV template is a guide to help in placement of different effects for each of the four faces.
- Shown here is just a small sample of what can be done using this map that covers each face edge to edge. UV offsets can be used for tiled maps to change the layout.
- Reflection, Glow, Overlay, and all other channels can be used to create unique styles that you control the look of.
- Normals can be used to raise or lower various facets or surfaces dependent on your needs. Displacement or Use of substances inside iClone6 can get various changes. The Real time smooth option inside iClone6 will not change the appearance much, but is available if you have the desire to try it.
- Resizing is simple to create thin or thick rings without changing the way a ring pattern looks except the scale.
- Want to use it as jewelry? Just attach to the finger of choice and scale to fit. Once scaled, you can use it again on other models with the same base hand structure. Adjust more for other characters.
- Want someone to pull it off and throw it? OK, that just requires a link and animation setup.
- To get some inspiration as to what can be made, just take a look here: http://www.tungstenfashions.com/Mens-Tungsten-Rings
Method of use:
