Highlights
  • Flip & Optionally duplicate these models to expand even more terrain features! - Double value
  • 8K PBR Textures Made with Photoscan Technology
  • Method included in instructions how to change color and keep detail
  • Simple method to convert entire Desert them to Snow/frost theme.
  • Sand & Snow both have glitter as well as the Sandstone on the Desert Cave prop
  • Included Documentation
Requirements: The physically bumpy surface relies on displacement textures, the quality of displacement relies on Smooth Mesh by Subdivision set to Level 1 and high tessellation resolution. Some game engine asset creators have solutions for runtime subdivision/crack free displacement and Screen Space Displacement which doesn't require tessellation creating unlimited detail with a major boost in performance.
At close range Displacement is required to get the full physically bumpy surface.
Two main Displacement Resolutions are provided. The default visible model and textures work with iClone when set to 4k or lower. A cloned model is attached and should be detached and enabled for iClone when set to 8K as it uses the proper Displacement EXR format for 8K. All other textures provided are 8K and should be copied over to the cloned model ***except for the displacement map***.
Readme file: Documentation.txt
Universal
PBR
