Set > Props (99)
This is a beautiful PBR complete Scene of Garage filled with tools and supplies for completing any building or repair task. The Garage itself has built in ANIMATION on the Garage Door and the Entry Door with a PERFORM menu for open or close. The side walls and the ceiling can be hidden for Camera angles. Props are attached to walls so they can be hidden in one click along with the wall. All items are sub-props which can be deleted or moved. All the cupboard doors can be opened/closed on the timeline.
These are high quality PBR textures including Base Colour, Normal, A/O, Metallic & Roughness - along with Emission for the Lights for adjusting with your lighting.
You also get all all the single props in a folder for adding to the scene or for use in your own projects.
iClone > Set > Props > Tools & Equipment
