Animation > rlMotion (1)
Set > Props (1)
The bathtub has built-in animation (see red-framed promo above) to fill the tub with water (drain closes, faucets turn on & water pours from spout as bathwater rises); the water in the tub has an animated texture to simulate the way water behaves in the bath; and lastly to drain the tub (drain lever moves to down position and water "drains" out of the tub). All of the built-in animation can be edited in the timeline to suite your filming needs. The bathwater, faucets handles, spout, running water & drain lever are sub-props, so feel free to delete the built-in animation and build your own, if desired.
PLEASE NOTE: Animate water textures for bathwater water & faucet pouring water rely on Reallusion stock Shared Templates. If you receive an error loading message, it is a simple fix. For the prop in question, go to your Modify Panel on the Texture tab & click on the BUMP map icon. Then navigate to the drive where you have your Reallusion content stored - then follow this path: \Reallusion\Shared Templates\Video\Water & select the bump map video (example for bathwater it is WaterNormal06.avi). You can then stretch the video in the timeline to cover your filming needs.
The included character animation mimics a person lounging in their soaker tub and though created for the base female avatar, can be used with any avatr with minor tweaking.
Kindly note that avatar, bathroom architecture, backgrounds, window view, towels & towel caddy are NOT included with this pack.
iClone > Motion > Daily Life > Other Motion of Daily Life
iClone > Set > Props > Devices
