  • Set > Props (4)
Bigboss is extremely proud to announce the arrival of a series of amazing physics enabled iClone Props by Cricky.
These are the Physics Corrugated Buildings by Cricky.
This Pack contains 4 corrugated building structures (2 Soft Cloth and 2 Rigid Side versions). The Soft Cloth versions make use of Soft Cloth Physics to simulate wind affecting the structure plus a desert sand physics base. In regards to the Rigid Structured buildings, the components are separated, e.g. you can open each door, or extend the building using more of the ribbed (corrugated) pieces and bows.
The doors on the structures can either be rotated downward or slid to the side, the pivot points are preset. Each door is operated independently.
The Shiny Corrugated Hangar has some additional (Black) rib fillers which delineate and define the ribs more so than just butted joints. They can be removed without destroying the integrity of the overall structure.
Method of use:
1) Load Prop into your scene
2) Set Play Mode to ''By Frame''
3) Press Play...
Notes:
- When playing, you may see the effect of the soft cloth physics simulation represented by a light blue color in your viewport. This is just a visual aid that will not be visible in the final render.
- For more information, please refer to the detailed PDF provided by the author in attachment.
These Props were created by Cricky.
Have fun!
Universal
