Set > Props (1)
This is the Physics Pup Tent COMPLETE by Cricky.
This pack contains a completely assembled Soft Cloth Pup Tent Physics Prop with connections of all parts and with their optimal physics settings already applied plus a demonstration of the Tent's physics dynamic motion right out of the box. You can experiment with the physics settings to see what best fits your scene or situation; The motion can be mild or look as if the tent is experiencing high wind gusts, while staying anchored to the ground.
A must have for all Camping Lovers !!!
IMPORTANT NOTES:
1) The Soft Cloth dynamics are based on how the Physics properties are set. Keeping your World Scale Low (1, 2, 3,etc.) and a constraint stability scale of (3) or Greater will give you better results. Also keep the animation for all your Physics props in a Frame-By-Frame viewing status.
2) The moving force box dummy included in the prop can be removed as desired or made inert in the physics panel using the rigid states options available on physics props in iClone.
3) The two flaps on the opening can either be used or discarded, depending on the needs of the user. The materials are simple to change or edit.
Method of use:
1) Apply Soft Cloth one Piece Pup Tent Prop to your scene
2) Set Play Mode to ''By Frame''
3) Press Play...
This Prop was created by Cricky.
Have fun!
iClone > Set > Props > Exterior Prop
