Project > Project (1)
Set > Props (1)
This is the Physics Water Tiles by Cricky.
This Pack contains an iClone ready project with an already assembled River consisting of adjacent water tiles plus a single water tile physics Prop. The water surface dynamics is modeled using a self actuated soft cloth.
This is an amazing and versatile physics prop. This product features a dynamic water tile you can Multi-Duplicate with the ''Snap To Grid'' iClone preference option set to get the squares exactly adjacent with each other and create custom made rivers, a lakes or even an fantastic ocean! . You can change the Texture as you want for various water looks. Furthermore, with the correct lighting, you'll have an efficient ocean of water !!!
You can also group and attach water tiles with most other props inside iClone creating your very own water front terrains !
A must have for all Water and Boat Scene Lovers !!!
IMPORTANT NOTES: The water dynamics is based on how your Soft Body Physics are set. Keeping your World Scale Low (1, 2, 3,etc.) and a constraint stability scale of (3) or Greater will give you better results. Also keep the animation for all your Soft Body props in a Frame-By-Frame viewing status.
Method of use:
1) Load Sample Project
2) Set Play Mode to ''By Frame''
3) Press Play...
4) Press Stop
5) Goto your iClone Preferences Menu
6) Set ''Snap to Grid'' option
7) Select PhysicsWater(0) Prop in Scene manager panel
8) Move PhysicsWater(0) tile around to your liking
9) Press Play!
This Prop was created by Cricky.
Have fun!
Bigboss40@videotron.ca
iClone > Stage > 3D Scene > 3D Exterior Scene
iClone > Stage > 3D Scene > 3D Nature Scene
