For iClone only:
  • Actor > Legacy Standard Human (1)
  • Animation > iMotion (6)
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D. This is a Pig by Arteria3D. This Pack contains a Pig. The Pig was ported to iClone by Bigboss. It is presented as non-human .iAvatar that can be fully animated inside iClone. Furthermore, the Pig comes with its own AML persona and 6 high quality motions; Idle, Walk, Feeding, Itching, SittingIdle and Step Back. The Walk motion is perfect cycle that can be repeated on the timeline. You can also operate the Pig in iClone Director Mode ! The Ears of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor. IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\Pig\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to: C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\ Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \Pig\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu Have fun! Bigboss40@videotron.ca
Standard Human
