For iClone only:
  • Actor > Accessories (2)
  • Actor > CC iCloth (4)
  • Set > Props (1)
Base Content
Plain Dress Based on Medieval Tunic by Delerna
4 Plain day-time dresses made from the Medieval Tunic Cloth by Delerna. You must own the base cloth linked below in order to use these iCloth.
Pack includes Gold Buckle Accessory shown in Promos plus a Collar-type Accessory for the Mauve Dress. It's a static accessory so might not look right in extreme motions. Can easily be hidden if desired.
Will install as follows in your iClone Default Directory -
iCloth - Body Part/CC iCloth/CC_Alley/Delerna_Plain_Dress
Accessories - Accessories/CC_Alley/Delerna_Plain_Dress
I've also included a Flat Plane iProp with a texture for an opacity map that can be used on your character to disguise any skin Show Through. Add the prop to your scene, highlight the Opacity channel on the right and export the texture for the opacity to a folder. When using the iCloth on other characters, if you need the skin opacity, add it to the Opacity Channel of the Body/Skin of the Character. This prop will install in your iClone Default Directory -
Props/CC_Alley/Delerna_Plain_Dress
NOTE: This pack requires Medieval Tunic by Delerna - Click on Thumb below for link.
CC1 CharacterUniversalUniversal
