Actor > Accessories (1)
Material > Substance (2)
Animation > Hand (1)
Character > Cloth (4)
Character > Shoes (1)
Material > Material (5)
1. Cloth models in this pack have been created for CC Male character and it's not recommended to use them with female.
2. To avoid DRM issues this pack includes previously published Cloth Bases with "Traditional" shader, but because these bases already have all necessary Mesh Data textures You can easy create PBR version of them using step-by-step instruction from ZIP file.
If You already have this pack cloth bases You can purchase "PBR Materials only" version.
The pack includes 5 cloth bases and 5 ready-to-use PBR materials.
Base models oriented on use as templates in CC Appearance Editor -- they have all main textures (Normal, AO, WS Normal, RGB Mask with up to 2K resolution) and empty Fabric definition (You can define fabrics and effects as You like).
Materials have .iMtl file format and can be applied in iClone7 (resolution of textures up to 2K).
What in Pack:
- Upper -- 3 Bases and 3 Ready-To-Use materials;
- Lower -- 1 Base and 1Ready-To-Use materials;
- Shoes -- 1 Base and 1Ready-To-Use materials;
- PBR version of SciFi Pistol Accessory with Ready-To-Use materials;
- Hands Gesture for SciFi Pistol;
Also in pack:
ColorTune substance tools which allow to tune cloth colors directly in iClone using RGBMasks.
PRCCM_SF1_PBR.zip file includes copies of RGB Masks for base models and documentation.
Please read this documentation before using the pack.
More information can be found in "PRCC Products Line by Vit3D " forum post.
If You will have any questions and/or suggestions You can post them there.
