For iClone only:
  • Set > Props (2)
This is a texture and Shoe Construction Set morph setting for a pair of Real Wear, half laced, brown, leather, hiking boot..
As the below Base Requirements indicate, this texture and morph setting requires Lord Ashes' Shoe Construction Set base.
Watch the video to see how easy it is to apply textures, opacity and morph settings to the Shoe Construction Set base.
(The video is for a different set of shoes but the exact same process applies to the Real Wear, half laced, brown, leather, hiking boot)
How To Use:
1. When you download this item you will get the texture and opacity file. Apply these to the Shoe Construction Set shoes
2. Download the attached "Strap Shoe Morph.iTalk.Zip" file. Unzip it and to a iTalk file.
3. Apply the iTalk file (by drag and drop) it to the shoes. This will apply the correct Shoe Construction Set morph values.
(Sorry...the iTalk file has to be download manually from below because iTalk files are currently not accepted by the Content Uploader to be included as port of the item content)
UniversalIC-Non-Exportable
