Animation > iMotion (6)
RF_BackWalkStCycle
RF_Graze
RF_Idle
RF_RunStCycle
RF_Scared
RF_WalkStCycle
G3 Skintight ANIMAL KINGDOM.iAvatar Red Fox by Arteria3D
Bigboss is extremely proud to announce the arrival of a series of absolutely outstanding and stunning Animals by Arteria3D.
This is a Red Fox by Arteria3D.
This Pack contains a Red Fox. The Red Fox was ported to iClone by Bigboss. It is presented as non-human .iAvatar that can be fully animated inside iClone.
Furthermore, the Fox comes with its own AML persona and 6 high quality motions; Idle, Walk, Run, Scared, Graze and Step Back. The Walk and Run motions are perfect cycles that can be repeated on the timeline. You can also operate the Fox in iClone Director Mode !
The Jaw and Ears of the Animal are skinned to separate bones so that you can also animate them using the iClone Motion Layer Editor.
IMPORTANT NOTE: The Motion files for this Animal must reside in the "$iClone Template\Motion\RedFox\" folder for the AML to find its way to the motion files Whereby "$iClone Template" environment variable typically translates to:
C:\Documents and Settings\All Users\Documents\Reallusion\Template\iClone 4 Template\iClone Template\
Unfortunately, in REALLUSION City, upon download, the installer will put all motions in the iClone Root Motion folder, i.e. "$iClone Template\Motion\”, thereby, once the installation is complete, you need to create a sub-folder and copy the supplied motions into that folder for the AML to work, i.e create a \RedFox\ sub-folder and copy all motions into it. This will then enable you to invoke motions directly from the Avatar Right^Click Pull-Down Menu
Have fun!
Bigboss40@videotron.ca
