An animated Reel to Reel projector with spinning reels (right click -> perform command) and projector sound effects.
Projection Sounds by NemoDaedalus from Freesound.org via the Creative Commons Attribution License (free to use for commercial use with attribution). The sound effect is attached to an invisible subprop called SOUNDCUBE. Select the subprop and you will see the sound effect in the timeline and in the control panel.
Projector stand, lens glow and light cone are sub props that can be turned off or removed to fit the situation. Lens Glow will not work with the Light Cone as glow maps dont appear behind semi-transparent objects in iclone.
