  • Set > Props (275)
Residential House by NOT Lonely - PBR
This is a special Early Bird Pricing available only until Nov. 9.
HQ Residential House is an American Style home which includes the house exterior, along with 13 rooms or hallways typically found in large family homes. Each room is supplied fully furnished to get you started quickly. Also, the entrance Door to each room has an animated PERFORM entrance door, along with wall Sections and ceiling that can be hidden for camera angles. As an added bonus, we are able to utilize the advanced features of iClone 7 by using a substance graph, thus allowing many iof the supplied items to be customized to your own unique colour scheme. Rooms included are:
1) Living/Dining Room
2) Kitchen
3) Family Room
4) Kids Room
5) Baby Room
6) Main Bedroom
7) Laundry Room
8) Office
9) Main Bedroom
10) Ensuite Bathroom
11) 2nd Bathroom
12) Hallways
In addition, the Outer House Shell is supplied and can be customized the same way. Select the brick colour, the trim, the siding using the substance graph embedded. The main shell has a front door that has a PERFORM for Open and Close. The double Garage Doors have a PERFORM for Open and Close.
In addition, you get over 260 single props with PBR texturing for creating your own customization to the rooms or for use in other projects. Items such as furniture, walls, windows and window coverings also have the substance graph, allowing you to create your own signature look.
NOTE: Rooms are supplied with coordinates set to 0-0-0. If you want to add the rooms in position inside the house, the coordinates are in the attached ReadMe. Note the coordinates assume the room PIVOT is set to middle in the drop down list and middle dot selected. Please note that if you want to do this, you are best to set your maximum texture size for the project to 512 x 512 as the entire house with PBR textures will be challenging for your system. It is suggested that most filming would be done inside a single room or perhaps two rooms if you wish to walk from one room to another.
ADDED: ReadMe File now attached with the XYZ Coordinates for the rooms.
Universal
PBR
