Character > Avatar (2)
Character > Cloth (1)
Character > Project (1)
Character > Skin Preset (5)
RL Hair > rlHairStyle (1)
RM3D Haruto
The pack contains CC3+ Haruto Character with cloth, hairstyle, brows, beard, 5 Tattoos, and Baggy Joggers.
The head and body were completely redesigned with external software. Ready for CC4 / IC8.
All tattoos are as layers, they are not burned into the texture, so it is possible to turn them on/off as needed.
For more information, check out the videos. PBR map resolution is 4K.
Relevant information:
This avatar was primarily created for Character Creator 3. Although the system says that Character Creator 4 is required, this package contains both versions (for CC3 and CC4 software). Converting from CC3 to CC4 often creates problems during the conversion of characters and their components, so I decided to include the already converted version. So if you are using Character Creator 3 and have not yet upgraded to Character Creator 4, you don't have to worry about not opening the avatar. Check by downloading the corresponding trial version of the avatar. The converted avatar is in 4K resolution, if you need to reduce the resolution to 2K (or less) due to system memory, either convert in Skin Editor (Modify/Skin/Activate Editor) or burn the textures (Character/Burn All Skin Textures).
- 1 Haruto Character (CC3+ Avatar, 4K PBR materials)
- 1 Hair (4K, hair and scalp)
- 1 Brows (4K)
- 1 Beard (4K)
- 5 Tattoos (2K-4K, Jakuza Style)
- 1 Baggy Joggers (4K)
*Tested and Rendered in CC3 / CC4.
*2022-12-22 - small update (improved facial vertices)
*2023/01/24 - Added converted avatar for Character Creator 4
*IMPORTANT
When importing a CC3+ character into CC4/IC8, it is necessary to apply eyelid correction in CC4 first (otherwise they will be deformed):
1. - CC4 Extended (140+)
2. - Character/Correct Eyeblink
3. - Fix Eye Element
Please try before you buy.
