  • Character > Accessory (338)
RM3D Horns 01 is a pack of 16 shapes of horns with 338 material variations.
Each horn has special UV mapping with PBR 4K textures.
Materials are PBR and Iray ready (of course not precisly same cause PBR and Iray are different types of render).
All horn materials contain 4K JPG for Base Color, Normal, Metal, Roughness.
According to needs also Ambient Occlusion, Displacement, Glow and Blend textures.
All previous pictures are rendered in the default PBR render system of Character Creator 3 or iClone 7.
Is very easy to manipulate with horns or is possible to add more than one horn, deform its or scale as your project needs.
Also, you can easily change or modifficate all materials by using different settings by slides in the Material slot as power off glowing, sub scattering, etc. Or change Colors Base (and/or other bitmaps) by modification of Color Base texture (HUE, Bright slide in Adjust Color Setting for example).
Please try before you buy.
Universal
PBR
