For Character Creator only:
Character > Project (1)
Character > Avatar (2)
Character > Cloth (20)
RL Hair > rlHairStyle (1)
RM3D Millie
The pack contains CC3+ Millie character ready for CC4 / IC8. The head was completely redesigned with external software.
For more information, check out the videos. All 4K materials are ready for PBR/IRAY.
If you need more material variants of cloth, you can buy this expansion here: RM3D Long Sleeve Top
Relevant information:
This avatar was primarily created for Character Creator 3. Although the system says that Character Creator 4 is required, this package contains both versions (for CC3 and CC4 software). Converting from CC3 to CC4 often creates problems during the conversion of characters and their components, so I decided to include the already converted version. So if you are using Character Creator 3 and have not yet upgraded to Character Creator 4, you don't have to worry about not opening the avatar. Check by downloading the corresponding trial version of the avatar. The converted avatar is in 4K resolution, if you need to reduce the resolution to 2K (or less) due to system memory, either convert in Skin Editor (Modify/Skin/Activate Editor) or burn the textures (Character/Burn All Skin Textures).
Translated with DeepL
- 1 Millie Character (CC3+ Avatar, 4K PBR materials)
- 1 Hair Style (no physic, 4K)
- 1 Eyebrows (2K)
- 10 Long Sleeve Top (4K)
- 6 Shorts W1 (4K)
- 1 CC3 Sample Scene Project
*2022/06/04 - Added four material bonuses for Long Sleeve Top with "Millie" text.
*2022/06/05 - Small correction of Skin Weights in the underarms of the Long Sleeve Top cloth.
*2023/01/24 - Added converted avatar for Character Creator 4
Please try before you buy.
- 1 Eyebrows (2K)
- 6 Shorts W1 (4K)
