For Character Creator only:
  • Character > Accessory (4)
  • Character > Avatar (3)
  • Character > Cloth (2)
  • Character > Expression Wrinkles (1)
  • Character > Project (1)
  • Character > Shoes (1)
For Cross Product only:
  • RL Hair > rlHairStyle (1)
For iClone only:
  • Animation > rlMotion (1)
RM3D Sandra  with Expression Wrinkles update
   The pack contains CC3+ Sandra Character with hairstyle, brows, bracelet, ring, earrings, dress, and heels.
 The avatar is natural, without make-up, the user can easily implement his own.
 The head and body were completely redesigned with external software.
  For more information, check out the videos. PBR map resolution of Avatar is 4K.
More material variants of the dress - RM3D Dress A (10 variants)
Completely redesigned three layers of PBR textures according to RM3D Sandra character's specific wrinkles.
Relevant information:
This avatar was primarily created for Character Creator 3. Although the system says that Character Creator 4 is required, this package contains both versions (for CC3 and CC4 software). Converting from CC3 to CC4 often creates problems during the conversion of characters and their components, so I decided to include the already converted version. So if you are using Character Creator 3 and have not yet upgraded to Character Creator 4, you don't have to worry about not opening the avatar. Check by downloading the corresponding trial version of the avatar. The converted avatar is in 4K resolution, if you need to reduce the resolution to 2K (or less) due to system memory, either convert in Skin Editor (Modify/Skin/Activate Editor) or burn the textures (Character/Burn All Skin Textures).
- 1 Sandra Character (CC3+ Avatar, 4K PBR materials)
- 1 Expression Wrinkles (4K)
- 1 Hair (4K, hair and scalp)
- 1 Brows (2K)
- 2 Evening Dress (8K, Base+PhysX)
- 1 Heels C  (4K)
- 1 Bracelet  (2K)
- 1 Ring  (2K)
- 2 Earrings  (4K, L+R)
- 1 Motion Pose  (RM3D Sandra Pose)
- 1 Sample Project
*Tested and Rendered in CC3 / CC4.
*2023/01/24 - Added converted avatar for Character Creator 4
*2023/02/25 -  - Completely redesigned three layers of PBR textures according to RM3D Sandra character's specific wrinkles. It is necessary to update CC4 to version 4.2 and update the purchased package. A new avatar will be added with the name "RM3D Sandra CC3 (with Wrinkles CC4).ccAvatar", and "RM3D Sandra Expression Wrinkles 4K.rlWrinkle".
  *IMPORTANT
When importing a CC3+ character into CC4/IC8, it is necessary to apply eyelid correction in CC4 first (otherwise they will be deformed):
1. - CC4 Extended (140+)
2. - Character/Correct Eyeblink
3. - Fix Eye Element
Please try before you buy.
CC3+ CharacterCC3+ CharacterCC3+ CharacterCC3+ CharacterCC3+ CharacterUniversalCC Component
Human ShaderPBRSubstancePhysicsTraditionalExtendedGeneral Wrinkles
