For iClone only:
  • Project > Project (8)
  • Actor > Non-Standard Human (1)
  • Set > Props (4)
  • Stage > Lens Flare (1)
RM3D Space Kit - Earth with Moon
A total of eight pre-prepared space scenes that can be used immediately for your movies. All scenes can be seen in the video, - they are output from iClone 8 without post-production. The scenes contain different views of the spherical Earth and Moon objects in realistic resolution ranging from 8K to 23K. Other projects include a Space Station model, three different asteroids and a simplified astronaut character. The scenes contain several effects and a spherical star map at 16K resolution, which is realistic as far as our star system is concerned. For proper operation, I always recommend to use an already created camera in the scene, because some of the Earth model materials are on hanging. (If you want to use other cameras in the scene, you need to "link/look at camera" these maps with the "cam_linked" label to the camera you are using).
In this project, due to the use of high resolution maps in the materials, I recommend at least a third generation GPU with 12GB RAM. If you notice a problem with scene loading in this regard, I recommend downsizing the maps. You can do this before uploading the project in the "Preferences/Max Texture Size" tab and downgrade the textures here.
All scenes were created and tested on a PC configuration with 32GB RAM, GeForce RTX 3060 12GB
The package includes:
 4 (+3) - Scene Projects for immediate use (4 projects with Earth and Moon + 3 projects with examples of moving asteroids​)
 1 - Earth 3D model (8K/16K) with clouds and atmosphere effects
 1 - Moon 3D model (13K/16K)
 1 - Space Station 3D model (4K) in neutral colors
 1 - Astronaut (actorBUILD, 4K) in neutral colors
 3 - Asteroids (2K) in three different materials and shapes
 1 - Flare Effect
 1 - Sperical Star Map (16K)
Future plans include additional solar system planets, exoplanets and more.
If you are looking for aerial views/flights over the terrain of Earth or other planets - check out this product:
RM3D Terrain Material (109+ variants)
RM3D Space Kit - Jupiter with moons
RM3D Space Kit Stars and Beyond
I have a wish, question, or idea for RM3D
Body Ready CharacterUniversalUniversal Project
PBRPhysics
