Project > Project (2)
Set > Props (6)
A pre-prepared space scenes that can be used immediately for your movies. All scenes can be seen in the video, - they are output from iClone 8 without post-production. The scenes contain different views of the spherical Jupiter and his moons objects in realistic resolution ranging from 8K to 4K. Two different meteorites (each with 3 material variants). The scenes contain several effects and a spherical star map at 16K resolution, which is realistic as far as our star system is concerned.
Moons of Jupiter contain animated orbits in a realistic distribution, angles and ratio to the size of the planet Jupiter, if you want them to be stationary, - just delete the animated layer. The planet Jupiter itself is composed of three parts, which are animated differently to give the impression of moving gaseous belts/flows.
In this project, due to the use of high resolution maps in the materials, I recommend at least a third generation GPU with 12GB RAM. If you notice a problem with scene loading in this regard, I recommend downsizing the maps. You can do this before uploading the project in the "Preferences/Max Texture Size" tab and downgrade the textures here.
All scenes were created and tested on a PC configuration with 32GB RAM, GeForce RTX 3060 12GB
The package includes:
2 - Scene Projects for immediate use with Jupiter and moons
1 - Jupiter 3D model (8K) with animated flow and caps effects
4 - Moons 3D models (8K/4K, Europe, Io, Ganymede, Callisto)
2 (x3) - Meteorites (4K) in three different materials
1 - Flare Effect
1 - Sperical Star Map (16K)
Future plans include additional solar system planets, exoplanets and more.
If you are looking for aerial views/flights over the terrain of Earth or other planets - check out this product:
RM3D Terrain Material (109+ variants)
RM3D Space Kit - Earth with Moon
RM3D Space Kit Stars and Beyond
I have a wish, question, or idea for RM3D
iClone > Project > Theme > Modern Project
iClone > Project > Theme > Sci-Fi Project
iClone > Set > Props > Space Vehicle
