For Cartoon Animator only:
  • Scene > Props (3)
Rocket, Launch & Flight - The elements that are most important here are the FIRE ELEMENTS. PLEASE NOTE: These elements are ANIMATED PNGs, not mov files. The Rocket is a giveaway item to link with the launch and flight Animated PNG sequences - which will play normally in Cartoon Animator 5. The fire was created with a particle system and broken into a launch element that you only loop once, and a flight element that you loop for however long you need it. The tutorials will show you how to use these elements so that they work seamlessly together, as well as how to link them to your rocket or other items so that they fire elements will animate with the rocket.
Universal
Vector
