For iClone only:
Rockin Drum Pack
Finally a drum pack for the Iclone 6 and CC Characters. The drum pack comes with the complete drum kit, sticks and 10 animations to get your characters drumming like a pro. All the animations sync up with each other so you can put together your own drum beat configurations.
The animations consist of an idle pose where the character sits and waits to play. Then you have an idle to play where the character gets ready to play. You can then add in a basic drum beat or one of the two fills to start things off. There are 3 basic drum beat patterns. Two of these use just the bass drum pedal and the other incorporates the bass drum pedal and the high hat pedal. You also get two drum fills for some real action on the drums. There is a repeat for fill 01 to have the character repeat the fill over and over again for a cool drum solo. (see Video) I have also included two animations for cymbal hits. One hits the ride cymbal and one hits the crash cymbal.
The drum set comes already set up and ready to play on. The animations work great with the current set up but you can move the drums around any way you wish because they are all separate props. The ride and crash cymbal come with perform animations so you can make them vibrate when struck. The foot pedals on both the bass drum and high hat are able to be animated with their own perform animations built in. The pedals are animated to move up and down so that the character can press the pedal down with his foot. Also on the bass drum the kick has a perform animation that makes it hit the bass drum. The high hat cymbals also have a perform animation built in so that they will move up and down and clash together.
You also get a pair of drum sticks as accessories. Just click to add them to the scene and they will attach to the characters hands.
The animations were built around the Christian character that comes standard with Iclone 6, but you can use any character you wish. If he is taller or shorter you will have to adjust some of the animations to hit the drums properly.
The basic drum beat animations are in 4/4 time so it should work with most songs. You can always extend or shorten the beats to compensate for faster or slower songs. (See videos to see some different tempo songs as examples of what can be done with these animations)
You will have lots of fun with this pack!
*The perform animations on the props do not work in version7 for some odd reason. They do work perfectly in version 6 which is where I created all of them. I have technical looking into this. Everything got screwed up in an update that they did. You can still animate everything manually though.
Update:
Iclone 8 has solved the problems with the perform animations. See tips PDF for more info.
See the Rockin Guitar Pack Here!
Readme file: Some Tips revised.pdf
Standard HumanUniversalUniversal
