For Character Creator only:
  • Character > Avatar (2)
  • Character > Cloth (2)
  • Character > Shoes (1)
For iClone only:
  • Actor > CC Standard Human (2)
Base Content
Rompers for Ivonne from Cartoon Character Designer - in PBR
NOTE: To use this "Character", you need the Cartoon Character Designer Pack by Reallusion or you will get watermark.
To use the "Cloth", you can apply to any CC Character, provided you own the cloth bases, however the mesh was altered on the catsuit specifically to fit the toon female, as well as the shoes - therefore they may not fit properly.
From the "Ivonne's Closet Collection", this is the Romper modelled on Ivonne. The character is wearing the Catsuit Base from the "Professional Clothing" pack by Reallusion and Shoes are default. High Heels have had the mesh adjusted to fit Ivonne's foot better. All are set up in CC3 so that you can launch the appearance editor and apply your own textures if desired.
The dressed avatars are supplied in both CC3 and iClone for your convenience.
Opacity maps have been applied to the "Body Skin" to assist with hiding skin poke-through that may happen in some motions. Save these opacity maps for adding to other toon characters that use the cloth applied to the base.
Will install as follows:
CC3 -
Rompers - CC3/Cloth/Full-body/CC_Alley/Rompers
Shoes - CC3/Cloth/Shoes/CC_Alley/Ivonne's_Closet/Rompers
Avatars - CC3/Avatar/Clothed/CC_Alley/Ivonne's Closet/Rompers
iClone -
Avatar/CC_Alley/Ivonne's_Closet/Rompers
CC character will be wearing sun visor - can be purchased from link. Or simple delete it to remove the watermark.
CC1 CharacterCC1 CharacterCC3 CharacterCC3 CharacterCC Component
PBRExtended
