For iClone only:
Actor > Accessories (5)
Material > Lower Body (1)
Material > Shoes (1)
Material > Skin (1)
Material > Upper Body (1)
Set > Props (1)
Santa for "Chubby" from ToonMaker 2 by Reallusion
Everything you need to create a Santa Character for "Chubby" from Reallusion ToonMaker2 Pack. Santa Sack Prop also supplied.
1) Add Chubby to the stage
2) Add the "SUIT" upper
3) Add the "FLAT HEEL" shoes
4) Add the "SUIT" lower
4) Select Upper Tab at top and in Modify Panel on right, "Load Material" and navigate to your material files to find Chubby Santa UPPER.
5) Select Lower Tab and in Modify Panel on right, "Load Material" and navigate to your material file for Chubby SANTA Lower.
6) Select "Shoes" Tab and then Load Material and navigate to the SANTA Flat Heel Shoes.
7) Add the Accessories for SantaHat, Smoking Pipe, Flasses and Boot Fur Trim. (in folder in your content Manager under Accessories labelled ToonMaker2/Chubby/Santa.
8) Add desired eyes, nose, ears, beard, brows, moustache, sideburns, etc. from Accessories in ToonMaker2 pack (or you can also use ToonMaker 1 or Monster Pack Accessories if you desire).
9) Select "Skin" tab at top, and then "Hands" in modify panel drop down list....load the material for the white gloves.
ToonMaker by Reallusion is available HERE
Other ToonMaker 2 Characters you might like:
