For iClone only:
  • Actor > Non-Standard Human (3)
  • Set > Props (21)
  • Animation > rlMotion (2)
Bigboss is proud to announce the arrival of a series of outstanding and stunning fully animated Characters and Props by MaxBugor
This is the Animated Sci_Fi Line with Creature Prop by MaxBugor
This Pack contains 3 x Creature Character, 2 Creature Idle Animation , 3 Animated Arm Lines (same lines in 3 color scheme)  plus numerous Stand, Line, Hooks and Station detail Props for iClone.
About MaxBugor Props:
Each Prop uses high quality PBR shader maps and a very small polygon count providing excellent visual quality for close-up shots.
Technical Note: You can expose different Creatures by turning on/off opacity sliders on the Creature Character Materials.
Method of use:
1) Simply apply animated line, Creature avatar and detail Props to your scene
2) Apply idle animation to Creature Avatar and position Avatar under desired hook on the line.
3) Link creature Avatar to "B_Hooks" line sub-object
4) Select line prop, right click and select "Anim_Line" performance
5) Press Play
Body Ready CharacterStandard HumanUniversal
PBR
