For iClone only:
  • Actor > Non-Standard Human (1)
  • Animation > iMotion (20)
Sci Fi Trooper by DEXSOFT Games
Sci Fi Trooper comes with a 20 Motion PERFORM Menu consisting of Action and Stealth moves. In addition, he uses all standard iClone motions.
He comes holding his rifle allowing the motions with the weapon to be extremely accurate. Should you wish to remove the rifle, the instructions are as follows. For iClone 5 - Select the "Skin" tab and on the drop down list in the Modify Panel, Select the Rifle Material and move the opacity slider to zero. For iClone 6, with the Character selected, select the Materials tab and find the Rifle Material in the list, then move the opacity slider to zero.
Sci Fi Trooper is a body ready character, he has no facial animation.
Poly count is under 13000.
Body Ready CharacterStandard Human
