Project > Project (11)
Set > Props (4)
This is the EZ Set ''Sea Model'' by Bigboss.
This pack includes all assets of Bigboss's new Sea Model for iClone 3D plus 11 x Pre-Build Sea Environmental Sets including Sunset, Partially Sunny, Blue Moon, Foggy, Blizzard, Rainy Day, Partially Cloudy, Sunny Day, Cloudy Evening, Starry Night and Sea Storm.
Each Set include a number of special props carefully crafted to best represent various weather conditions and time-of day at the high seas. The Pack include 2 fully animated and exclusive Sea Water surfaces (50 x 50) and (100 x 100) jointly developed by Bigboss and Sen. Each surface was carefully modeled and animated using high end simulation tools to best represent the movement of Waves typically found under various weather conditions. The height of the waves can be directly controlled inside iClone by simply scaling the Prop on the Z axis. The Speed of wind can also be adjusted by compressing or extending the Water surface animation directly from the timeline.
The pack also includes a series of Sky Domes for representing weather conditions and Sea Bed. The Sky and Sea Bed use different materials that can easily be altered to your liking by changing the various material parameters or by loading a completely new texture image. The Sky Dome also carries embedded animations for rotating East or West. You can also apply an opacity Map to the Sky area of the Sky dome and experiment adding various iClone Skies and atmospheric effects to the scene!
I have also provided a number of different Dome Backdrops to further complement the pack by allowing you to apply opacity maps to the sky portion of the sky dome and simulate some level of depth; e.g. by adding Stars or a beautiful Sunset texture behind moving clouds.
The pack also includes an Arteria3D Boat that was fully Skinned by Bigboss. The Boat includes embedded animations for simulating the forces and deformations of the boat hull and a special effect for simulating the splashes when the boat hits the water top.
Also included:
- Seagulls SFX
- Water Splashes SFX
- Miscellaneous Props including a Moon, a Sun and Clouds.
Best use in Pirate Movies and in any Water Scenes Scene.
NOTES: This Pack requires iClone 5.5
Method of Use:
1) Open desired Set Project Template
2) Go to your Props folder
3) Apply Blue_Sea_50_50 Prop to the Scene
4) Apply Rocky_Boat Prop to the Scene
5) Apply Flock_of_Seagulls to the Scene
5) Press Play
6) Study how each Item is used in the Project
7) Use the different Items to Build your own scene.
Further customize by moving Props around or by adding additional Props and building your own Scene using the different Items provided in the Pack.
iClone > Set > Props > Exterior Prop
iClone > Set > Props > Nature Prop
iClone > Stage > 3D Scene > 3D Exterior Scene
